SeanGr61
Jun 14, 2017Aspirant
Orbi AC3000
I am thinking of purchasing the Orbi AC3000. We recently converted our garage to an office and our WiFi coverage doesn't extend to it. The garage is a separate building, situated just back from a...
SeanGr61
Garage is made of single skin red brick with plasterboard inner walls. Insulation in between brick and plasterboard.
- peteytestingJun 14, 2017Hero
if you struggle to get wifi to the shed now i think orbi will also struggle
think you would be better looking for an external wireles access point you can ue in bridge mode to get the ignal and then have a cheap ap in the hed connected to it
- TechloreJun 16, 2017Apprentice
The best solution for you(if possible) is probably going to be to run a wire.
When you introduce WiFi to the outside lots of variables come into play.
