Bettylou2020
Aug 21, 2020Aspirant
Orbi AC3000
I’m trying to set up and i get to where the router tries to join the Orbi WiFi address but it can’t connect and doesn’t come up on my WiFi settings?
Aug 21, 2020Guru - Experienced User
Are you using a wired PC and web browser to setup the RBR?
- Bettylou2020Aug 21, 2020AspirantNo, Using the app
- MstrbigAug 21, 2020Master
I know it can be frustrating.
Start again:
reboot ISP modem/router, reset Orbi router before connecting to ISP router, connect Orbi to ISP router and turn on, run the app to configure the Orbi router, following the instructions. This should get you setup, unless you are having an issue with WIFI on the device you are using for setup.
- Bettylou2020Aug 21, 2020AspirantI added a pix of the error. I reset router and orbi multiple times. I don’t get the orbi WiFi choice in my WiFi settings
- FURRYe38Aug 21, 2020Guru - Experienced User
Please try with a wired PC or laptop or wireles laptop and web browser...
Bettylou2020 wrote:
No, Using the app- Bettylou2020Aug 21, 2020AspirantI don’t know how to set up with a laptop? I don’t think they gave that option in the set up instructions.
- Bettylou2020Aug 23, 2020AspirantNo i was using the App. Even the Verizon tech could get the Orbi to connect to the router. I can’t shut off the Verizon WiFi or go directly through the modem in our basement the tech tried that also.
- FURRYe38Aug 23, 2020Guru - Experienced User
Is this a Verizon Orbi that you got from Verizon? if so, you'll need to keep in conect with verizon about this. They are responsible for support on there verizon FW developed Orbi.
- Bettylou2020Aug 24, 2020AspirantNo we got from Costco the Verizon tech was just offering to help.
