Stev3D
May 24, 2019Luminary
Orbi Access Control Not Working Properly (since FW update?)
Since I got my Orbi RBK50 (RBR50 router with RBS50 satellite) well over a year ago, I've been using Access Control set to "Block all new devices from connecting" until I specifically approve. Last w...
Stev3D
FURRYe38 , manually restoring this configution from scratch would be a terrible mess. From rebuidling acccess lists, properly naming devices, restoring address reservations -- it would take a long time to get things back to where they were -- all to test a hypothesis. If I could save, and subsequenly restore, settings, to the same end, that would be acceptible. Requiring me to start again from scratch would be the last straw between me and Netgear (they have failed me several other times, including on other devices, lately -- causing me to question their commitment to quality).
Do you know if it is possible to reload the same version of the OS/firmware (perhaps that would clean out some cobwebs)? Would factory reset followed by restoration from a recent (known to be working) configuration backup be the equivalnet?
Thank you.
michaelkenward
May 25, 2019Guru - Experienced User
This is what people warn against. If you reload saved settings it can resurrect bugs.
Try it and see.
If bugs return you have answered your own question.
It should not be necessary to reset a device. Do it only if you see problems.
- Stev3DMay 25, 2019Luminary
This is a recent issue, and I have configuration files going back to my beginning with the Orbi (June 2017), and the second most recent one is form March 29 — before this problem began. So, assuming my other, less-nuclear fix doesn’t work, I have a backup from when things were known to be working well.
I’ll post the outcome to this thread as soon as implement something (won’t be today).
- FURRYe38May 26, 2019Guru - Experienced User
If you've been using the same config since 2017, thre maybe lingering code or configurations that may not work well with newer FW. Thus a factory reset maybe needed. Yes we know a reset shouldn't be needed however well documented posts show that resets have fixed issues after FW updates. Factory reset, setup from scratch and test. If it's good, save off a NEW backup config to file.
- Stev3DMay 28, 2019Luminary
FURRYe38 michaelkenward and CrimpOn , I have an update. Recall that I wanted to avoid starting from scratch, and the common element in this problem was that I had approved the two newly-added devices from Orbi iOS (iPhone) app. So, disconnected the two newly-added computers (the Windows machine was hibernated, the Mac was shut down). Then, from the Web interface, I deleted the two access control entries corresponding to the downed machines, I then manually created "Allowed" entries for those two machines (by MAC address), and then broght them back up. And all is well.
This suggests (does not prove) that the culpret was the iOS app -- that by allowing them via that app, I created corrupted entries in the Access Control table. Clearly more research is needed, but thus far, 100% of the cases (all two of them) where I used the iOS app to approve them created this problem.
I would hope someone from Netgear might look into this -- especially since I see other threads
