dkornaros
Dec 10, 2020Tutor
Orbi Access Control not working (RBR50/BS50) with 2.7.1.60 firmware
I have an RBR50 (v1) and RBS50 (v1). They've been working flawlessly for 3+ years...That is until I manually updated to the latest firmware (V2.7.1.60). Oddly, Access Control (which I've never h...
CrimpOn
Dec 10, 2020Guru - Experienced User
dkornaros wrote:I have an RBR50 (v1) and RBS50 (v1). They've been working flawlessly for 3+ years...That is until I manually updated to the latest firmware (V2.7.1.60).
randomly blocks my laptop from accessing all websites...can't even run speedtest successfully. The Access Control list shows the device as connected and allowed the entire time. Reboot of laptop, router and satellite have no impact.
As soon as I turn off Access Control, everything works fine. When I turn it back on, behavior appears again.Should I roll back to prior release?
I agree that Access Control should keep a device from doing anything on the Orbi, or let it do everything.
Does the laptop have an ethernet port?
I'm assuming that no other devices are affected?
Is any activity blocked besides web? (i.e. can it do email? can it access local devices? Ping somewhere outside (1.1.1.1)
Personally, I have never seen the attraction of access control. I have a stupendously complicated WiFi password.
If this really is a bother and access control is a requirement, then "Go Back."
