Cookie-Monster
Mar 08, 2019Aspirant
Orbi Adding additional satellite
I have an Orbi RBK53 system (Router plus 2 satellites) which were delivered all with the same SSID and password.
I now wish to install an add-on satellite which came delivered with a different SSID...
Mar 08, 2019Guru - Experienced User
Factory reset the new satellite, wait for the top led to pulsate WHITE, hit the black sync button on back of the RBR then press the black sync button on the RBS. The new satellite should start to sync and the top led should turn BLUE.
I now wish to install an add-on satellite which came delivered with a different SSID and password.
Do I need to manually change the add-on satellite settings to be the same as the RBK system or will the system handle it automatically
