joshishekhar
Feb 15, 2020Aspirant
orbi admin password recovery problems (can't reach login screen)
Hello, I forgot my orbi admin password. i am trying to follow recovery steps, but when I go to orbilogin.net or routerlogin.net, the webpage brings up a disney splash screen/advertisement window. if...
joshishekhar
i have tried both firefox and chorome. same result.
CrimpOn
Feb 15, 2020Guru - Experienced User
Can you try going to the actual IP address of the Orbi router, rather than the DNS name? Mine is 192.168.1.1.
- joshishekharFeb 15, 2020AspirantYes. I tried that. Same result. :(
- CrimpOnFeb 15, 2020Guru - Experienced User
How about trying https://orbilogin.net
The browser will complain, "Invalid SSL Certificate", but just select "Advanced Options" (or whatever) and go to the site anyway.
If none of this works, it may be time to get out the paperclip and do a "Factory Reset".
