joshishekhar
Feb 15, 2020Aspirant
orbi admin password recovery problems (can't reach login screen)
Hello, I forgot my orbi admin password. i am trying to follow recovery steps, but when I go to orbilogin.net or routerlogin.net, the webpage brings up a disney splash screen/advertisement window. if...
DrJohnH
Jan 08, 2021Initiate
I have run into the same Circle problem and see there is still no resolution. It is entirely unacceptable to do a reset to recover a password. Netgear's response is a pile of s**t and I will not buy another Netgear product if this cannot be fixed post-haste.
- fmalloyJan 08, 2021Luminary
DrJohnH wrote:It is entirely unacceptable to do a reset to recover a password.
If you read these boards regularly you will see that the recommendation is to "factory reset" for any and every problem under the sun. Is it raining outside? Factory reset!
To make matters worse, there are lots of postings where a firmware update failed, and even a factory reset doesn't work, requiring some crazy TFTP gyrations and instances of bricked routers.
There are only two occasions where your router should get factory reset - 1) at the factory, and 2) when you're selling the router to someone else. To paraphrase Steve Jobs - if you need to fix the problem with a factory reset, you blew it.
- alokeprasadJan 08, 2021Mentor
We are all users here. Without access to NG's code or resources. So, when we get flummoxed, then factory reset provides a common starting point for starting over. It's not ideal, but it is the great equalizer and a place to start.
That is unacceptable situation for a well-designed hardware and firmware update process. NG-scanctioned FW update process should never need such back-door methods. But, if one is out of warranty, then it becomes the only thing to try. If NG pushes and installs a firmware without user intervention, then they should fix this even out of warranty. That is my opinion, but I could say that till the cows come home... I won't matter. Maybe a reasonable NG tech support or moderator would intervene then.
Agree 100%
- vajimApr 07, 2021Master
alokeprasad wrote:There are only two occasions where your router should get factory reset - 1) at the factory, and 2) when you're selling the router to someone else. To paraphrase Steve Jobs - if you need to fix the problem with a factory reset, you blew it.
Agree 100%
you left one out.....when you can't remember your password as recommended by Netgear
- bremer77Apr 07, 2021Aspirant
i had the same problem after the newe software update.
first of all i only had to typ in the username and then leave the password tray empty.
then i was abble to make a new password
- InLA90046May 26, 2021InitiateI am having the same problem.
Tried even buying a new Orbi system and it craps out for the URC smart home wired device
Orbi support just shoos you off the phone I hate Orbi- michaelkenwardMay 26, 2021Guru - Experienced User
InLA90046 wrote:
....it craps out for the URC smart home wired deviceSadly, I can't understand that.
What does "craps out" really mean?
What is a "URC smart home wired device"?
- FURRYe38Jan 08, 2021Guru - Experienced User
This time write down all important information for safe keeping later on after the reset. After makeing sure the system works after setting up, be sure to make a backup configuration to file for safe keeping. This saves time if a reset is needed again.
DrJohnH wrote:I have run into the same Circle problem and see there is still no resolution. It is entirely unacceptable to do a reset to recover a password. Netgear's response is a pile of s**t and I will not buy another Netgear product if this cannot be fixed post-haste.
