joshishekhar
Feb 15, 2020Aspirant
orbi admin password recovery problems (can't reach login screen)
Hello, I forgot my orbi admin password. i am trying to follow recovery steps, but when I go to orbilogin.net or routerlogin.net, the webpage brings up a disney splash screen/advertisement window. if...
DrJohnH
Jan 08, 2021Initiate
I have run into the same Circle problem and see there is still no resolution. It is entirely unacceptable to do a reset to recover a password. Netgear's response is a pile of s**t and I will not buy another Netgear product if this cannot be fixed post-haste.
Jan 08, 2021Guru - Experienced User
This time write down all important information for safe keeping later on after the reset. After makeing sure the system works after setting up, be sure to make a backup configuration to file for safe keeping. This saves time if a reset is needed again.
DrJohnH wrote:I have run into the same Circle problem and see there is still no resolution. It is entirely unacceptable to do a reset to recover a password. Netgear's response is a pile of s**t and I will not buy another Netgear product if this cannot be fixed post-haste.
