joshishekhar
Feb 15, 2020Aspirant
orbi admin password recovery problems (can't reach login screen)
Hello, I forgot my orbi admin password. i am trying to follow recovery steps, but when I go to orbilogin.net or routerlogin.net, the webpage brings up a disney splash screen/advertisement window. if...
fmalloy
Jan 08, 2021Luminary
DrJohnH wrote:It is entirely unacceptable to do a reset to recover a password.
If you read these boards regularly you will see that the recommendation is to "factory reset" for any and every problem under the sun. Is it raining outside? Factory reset!
To make matters worse, there are lots of postings where a firmware update failed, and even a factory reset doesn't work, requiring some crazy TFTP gyrations and instances of bricked routers.
There are only two occasions where your router should get factory reset - 1) at the factory, and 2) when you're selling the router to someone else. To paraphrase Steve Jobs - if you need to fix the problem with a factory reset, you blew it.
alokeprasad
Jan 08, 2021Mentor
We are all users here. Without access to NG's code or resources. So, when we get flummoxed, then factory reset provides a common starting point for starting over. It's not ideal, but it is the great equalizer and a place to start.
That is unacceptable situation for a well-designed hardware and firmware update process. NG-scanctioned FW update process should never need such back-door methods. But, if one is out of warranty, then it becomes the only thing to try. If NG pushes and installs a firmware without user intervention, then they should fix this even out of warranty. That is my opinion, but I could say that till the cows come home... I won't matter. Maybe a reasonable NG tech support or moderator would intervene then.
Agree 100%
- vajimApr 07, 2021Master
alokeprasad wrote:There are only two occasions where your router should get factory reset - 1) at the factory, and 2) when you're selling the router to someone else. To paraphrase Steve Jobs - if you need to fix the problem with a factory reset, you blew it.
Agree 100%
you left one out.....when you can't remember your password as recommended by Netgear
