bermannyc
Dec 17, 2018Aspirant
Orbi and Airport Extreme/Express printing
Hi
I'd like to use one of old Airport Extremes or Expresses to print wirelessly. Is this possible to do with the Orbi system? I mean add an Airport to the Orbi network without plugging it in di...
Dec 17, 2018Guru - Experienced User
if the AE support wireless bridging, then yes you could connect it to the Orbi system. You'll need to check with Apple about what AE products support wireless bridging. My 3rd Gen AE does.
- bermannycDec 17, 2018Aspirant
I can have the extreme join the new Orbi network BUT I can't get the printing to work. Is there a setting I'm missing?
- FURRYe38Dec 17, 2018Guru - Experienced User
I would check the IP address of the printer that it gets from the Orbi thru the AE when it's connected to the AE. The AE if wirelessly bridged and connected to the Orbi should pass thru an IP address to the printer. Your PCs with the printer driver should point to this IP address that the printer gets from the Orbi router. You'll need to contact the Mfr of the printer for additional help and information on this.
