Trmmcd
Aug 22, 2021Aspirant
Orbi and Ambient Weather 2902 - Not able to report weather to Internet
I have an Orbi router and an Ambient Weather 2902 station. The Weather Station connects to the Orbi without issue and I can see that it is connected using the Orbi app. However, the Weather St...
- Aug 22, 2021Thanks for the input. This started working. I’m not sure what changed though. For those who have had issues with 2.4Ghz vs. 5Ghz this is working fine now on a mesh satellite node broadcasting both frequencies which is what I would have expected.
CrimpOn
Aug 22, 2021Guru - Experienced User
It appears that the local network part of the process is complete. There is another item farther down the FAQ about
"Does not update Ambient weather net" about using the Ambient weather app to set a schedule, check the password, etc.
