stevelk9999
Aug 30, 2018Tutor
ORBI and Amcrest/Foscam
I recently had verizon switch my older coax for ethernet so I could switch to ORBI. The ORBI system worked great and I get excellent coverage.ut f
The only strange occurrence is with AMCREST...
stevelk9999
Aug 30, 2018Tutor
Thank you. The Foscam's are all working but I stil have problems with the Amcrest for some reason. I set up port forwarding on the router. I can easily see the port is open on canyouseeme.org. But when I try to view them on blue iris.. nada. I know how to use blue iris and have not experienced this before. I ditched the verizon router. Other than that one quirk, the Orbi system works perfectly. I will ditch the old amcres cameras and pick up a few Foscams. I am not using many cameras.
thanks
Aug 31, 2018Guru - Experienced User
Good Luck.
