rior
Sep 21, 2021Tutor
Orbi and Apple private relay
Apple’s new privacy service with iOS 15 doesn’t seem to work with Orbi routers. It works fine on 4G and other wifi routers but not my RBR50. Is this a known issue?
punkorambo
Sep 22, 2021Guide
I am on iOS 15 connected to my RBK50 router/satellite setup, using Apple Private Relay, writing this response with no problems. If you’d like any more info on my setup/configuration let me know.
Sep 22, 2021Guru - Experienced User
Please do post any of your Orbi and ISP modem configurations. Details will be helpful.
- punkoramboSep 22, 2021Guide
Optimum Online
Cable Modem: Arris SB6183
Default settings/setup
RBR50 FW 2.7.3.22
RSB50 FW 2.7.3.22
Wired connection
Router Mode
Parental Control: Not Enabled
Armor Security: Not Enabled
UPnP: Off
20/40 Mhz Coexistence: Enabled
WMM: Enabled
CTS/RTS Threshold : 2347
Preamble Mode: Automatic
Daisy Chain: Disabled
Implicit Beamforming: Enabled
MU-MIMO: Enabled
Fast Roaming: Disabled
- riorSep 22, 2021TutorHere’s the error message. I’m on the latest firmware and don’t have parental control or bit defender enabled. Good thing is you can disable the feature on specific routers so I’ve done that on my Orbi for now.
I just found another post here describing similar issue but on a MacBook.
https://community.netgear.com/t5/Orbi-WiFi-6/Netgear-Orbi-RBR850-is-not-compatible-with-Apple-iCloud-Private/m-p/2142295- punkoramboSep 23, 2021GuideI’m just not getting that error. I checked on my wife’s phone, and the iPad. Neither of those get that error either while connected to the Orbi.
