jasonlathrop
Nov 12, 2019Initiate
Orbi and Apple TV Gen 4
I have an Apple TV 4th Gen reporting excellent signal strength and not that far from my Orbi Router. SpeedTest.Net reports decent speeds, 30-40mbs, 12 ms ping, most of the time. But, about ...
Nov 12, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Do you have Circle or Armor enabled?
If you are running out of things to try, give these settings a shot.
- Preamble Mode: Short Preamble
- Disable Fast Roaming
Apply the changes and then reboot the Orbi router/Satellites and wait for the Satellites to fully sync with the router by going to Firmware Update page to verify that the Satellites are not stuck in "Waiting for connection".
