BenZona
May 14, 2020Follower
Orbi and Arlo resolution?
My ARLO system keeps dropping the signal. Like many others, I am experiencing total failure with these two products interacting. On my ARLO base unit I get three green bars, no problem. The ba...
May 14, 2020Guru - Experienced User
I've got an arlo connected to my orbi without any issues. Not sure why yours is having an issue.
You can put your xfinity device back in router mode (disable its wireless) and then place the orbi in Access point mode. That'd let you connect the Arlo to the xfinity router. And orbi would still work fine for wireless/ethernet in ap mode.
