jjon90
Oct 03, 2016Guide
Orbi and Arris touchstone TG2472 (Cox )
I can confirm that Orbi worked seamlessly with my Cox cable/wifi/telephone modem! I did shut down the wireless capability in the Arris prior to the Orbi setup! Orbi did improve the speed and connecti...
Trikein
Dec 24, 2016Luminary
How did you set it up? That gateway is not capable of being bridged because it has phone service attached to it. You should still disable the wireless on the gateway if you don't mean to use it. It will only mess with the Orbi wireless.
jjon90
Dec 24, 2016Guide
I did not set the Orbi up in bridged mode.
- TrikeinDec 25, 2016Luminary
Then you have double NAT. Hopefully you don't game or do any advanced networking.
- jjon90Dec 26, 2016Guide
If I remember I think I Put the wireless router in modem's DMZ. But it's been too long I can't remember how I did it. Bit not having any gaming conflicts/errors with ports.
- TrikeinDec 26, 2016Luminary
The DMZ bypasses the gateways(modem) firewall, but not it's NAT. NAT in router and NAT in gateway= double NAT. NAT is Network Address Translation. Its the system that allows the router or gateway to take the usually public IP from the WAN port and allows multiple private IPs (192.168.x.x) on the LAN and wireless. Since the gateway only hands out private IPs, the WAN port on the router gets a private IP instead of a public IP, which can cause issues. YMMV
