gr8sho
May 06, 2019Virtuoso
Orbi and ATT Uverse IPTV
Today I reconfigured my network to move all remaining traffic onto the Orbi, including IPTV. For those outside the US, one of the vendors that sells IPTV service is ATT and their product is called U...
gr8sho
May 20, 2019Virtuoso
The following is a bug report. Firmware level tested was v60.
The timeshift commands to the ISB7005 set-top box do not work when the receiver is Ethernet connected to the RBS50. I moved the receiver back onto the VAP2500 WAP connected to the RBR50 and the timeshift controls work properly. It appears the RBS50 may not fully support IGMPv3 protocols or some defect exists.
May 20, 2019Guru - Experienced User
What happens if you disable IGMP proxy on the RBR? Someone reported that disabling this on the RBR helped with the TV service get thru to the set top boxes over Orbi.
- gr8shoMay 20, 2019VirtuosoThat’s table stakes for IPTV to work at all.
So yes, that’s already unchecked. - FURRYe38May 21, 2019Guru - Experienced User
Possible that the IPTV just may not work at all thru Orbi. Or needs to be all connected with there required HW. I know that DISH wireless Joeys have to be connected to there own wireless AP and not external wifi such as Orbi.
- gr8shoMay 21, 2019Virtuoso
Anything is possible I suppose. But it was working. In fact it could be the upstream servers themselves as I've seen one other report like mine from a veteran user.
I did a full reboot last night and the only thing I stopped short of was factory reset of the gateway and the RBR50. I do think v60 has issues though.
And as for why I'm not using the native hardware support, it's because without running everything off the same network, I cannot use the remote control function over wifi built into the Uverse app. This has become more important to me to use over the standard IR remote. I'm at a point now I wish TVs and settop boxes would do away completely with IR and use either wifi of bluetooth to perform the remote command functions.
Well something to try as last resort with a reset.
IR has it's place in some areas. I know for DISH they dual band remotes so IR and UHF. I use IR repeaters were needed for my use.
The Uverse app thing, that would be there area of development and would check on its requirements for use with 3rd party wifi outside of there required HW.
If it has been working up to v60 then possible something on there side recently broke. Wouldn't be always something with Orbi. :smileywink: - gr8shoMay 21, 2019Virtuoso
I'd still like to either be able to report a bug for Orbi or at least get confirmation from Netgear that the RBS50 provides full support for IGMPv3.
As for Uverse itself, I don't need help with it from this community. I'm not sure how my messages are being misinterpreted but I'll try to do better to clarify my posts.
To the extend standards and specifications are beng implemented in the product, I do expect them to work no matter how obscure the usecase may be.
Cheers
Would be best place to let NG know:
https://www.netgear.com/mynetgear/registration/login.aspx
Might ask a forum moderator about IGMPv3. I presume it doesn't. And may not until Orbi AX arrives. Who knows.
Good Luck.
Is a thread like this okay and perhaps explicity tagging one of the moderators to respond? I'm not well versed on how to engage moderators here.
- FURRYe38Jun 02, 2019Guru - Experienced User
Did you ever get any information on this?
I see IGMPv3 in the UI of the RBR.
gr8sho wrote:Hello Blanca. Can you have a look at this thread please and in particular the question about requesting confirmation for support of IGMPv3 being extended to the RBS50 and it's attached clients.
Thank you!
- gr8shoJun 03, 2019VirtuosoHello. Haven't seen a reply.
Yes, for the RBR50, but the RBS50 I'm uncertain about. In other words, does IGMPv3 support carry across wireless backhaul to its wired clients. - FURRYe38Jun 03, 2019Guru - Experienced User
I would presume yes, however with Orbi, could be anything. :smileyfrustrated:
Have you tried wired backhaul with the RBS?
Yes, for the RBR50, but the RBS50 I'm uncertain about. In other words, does IGMPv3 support carry across wireless backhaul to its wired clients. - gr8shoJun 03, 2019VirtuosoThat’s not practical unfortunately.
If Netgear provides an official response and also needs or wants to do a deeper dive into the configuration, I’m willing to help where I can. I do in fact have interest in having a wired IPTV settop client connected to a satellite to simplify the overall network topology. - FURRYe38Jun 04, 2019Guru - Experienced User
Something to open a support ticket and see if you can send them the debug logs...
If Netgear provides an official response and also needs or wants to do a deeper dive into the configuration, I’m willing to help where I can. I do in fact have interest in having a wired IPTV settop client connected to a satellite to simplify the overall network topology. - gr8shoJun 05, 2019VirtuosoRight, and again, focus on the satellite, as the base works fine.
If talking to engineering, confirming support and validation testing is good enough.
Thanks so much for taking interest. - gr8shoAug 24, 2019Virtuoso
Hello, While I haven't heard back on this topic, nor have I seen mention of it in the patch notes, I decided to reconnect my ISB7005 back to the RBS50. So far it seems to be holding up well. I would of course feel better knowing something was done to improve this area of IGMP support in the satellite.
- FURRYe38Aug 24, 2019Guru - Experienced User
What was the version of FW prior to what you have loaded now?
Nothing in the release notes?
- gr8shoAug 26, 2019Virtuoso
I've stepped through most of them, but the better question is what was the last version I tested this on, and I'm thinking .44, but not 100% sure.
As to the release notes question, I hadn't spotted anything that seemed connected to the reported issue. - FURRYe38Aug 26, 2019Guru - Experienced User
Might ask Blanca_O to see if she can pull some infomation. I guess if v30 is working when it didn't work before. Anything could have snuck in.
As to the release notes question, I hadn't spotted anything that seemed connected to the reported issue. - gr8shoSep 20, 2019Virtuoso
Maybe it was just coincidence. Problems still seem to surface when power ins interrupted. I have to fiddle withi rebooting the settop box and hope that all functions are restored. The ones that are most problematic relate to being able to pause and rewind a live stream. Given that Uverse TV is going the way of the dodo bird, it's probably not worth fussing over any longer.
- FURRYe38Sep 20, 2019Guru - Experienced User
Its possible. Have you looked into getting a different modem with your ISP? Maybe a different ISP service?
- gr8shoSep 27, 2019Virtuoso
FURRYe38 wrote:Its possible. Have you looked into getting a different modem with your ISP? Maybe a different ISP service?
Made me laugh. Sure, I'll switch service to make my Orbi work better. And while I'm at it I'll drop 800 bucks on a new Orbi. 🤨
In all seriousness, it's more likely this setup will fade into past tense as U-verse TV , IPTV, is slowly fading into non-existence.
- FURRYe38Sep 30, 2019Guru - Experienced User
Overall just seems to be a bad problem between the ISP service and Orbi. Espeically with there Modem HW.
Wouldn't need to buy a new Orbi unless you wanted AX WiFi.
