gr8sho
May 06, 2019Virtuoso
Orbi and ATT Uverse IPTV
Today I reconfigured my network to move all remaining traffic onto the Orbi, including IPTV. For those outside the US, one of the vendors that sells IPTV service is ATT and their product is called U...
May 21, 2019Guru - Experienced User
typing @ will bring up a user list, Keep typing after the And can type in blancaO or Chistian_r or Ernest. BlancaO seems to respond more often. Or send them a PM.
gr8sho
May 21, 2019Virtuoso
Hello Blanca. Can you have a look at this thread please and in particular the question about requesting confirmation for support of IGMPv3 being extended to the RBS50 and it's attached clients.
Thank you!
- FURRYe38Jun 02, 2019Guru - Experienced User
Did you ever get any information on this?
I see IGMPv3 in the UI of the RBR.
gr8sho wrote:Hello Blanca. Can you have a look at this thread please and in particular the question about requesting confirmation for support of IGMPv3 being extended to the RBS50 and it's attached clients.
Thank you!
- gr8shoJun 03, 2019VirtuosoHello. Haven't seen a reply.
Yes, for the RBR50, but the RBS50 I'm uncertain about. In other words, does IGMPv3 support carry across wireless backhaul to its wired clients. - FURRYe38Jun 03, 2019Guru - Experienced User
I would presume yes, however with Orbi, could be anything. :smileyfrustrated:
Have you tried wired backhaul with the RBS?
Yes, for the RBR50, but the RBS50 I'm uncertain about. In other words, does IGMPv3 support carry across wireless backhaul to its wired clients. - gr8shoJun 03, 2019VirtuosoThat’s not practical unfortunately.
If Netgear provides an official response and also needs or wants to do a deeper dive into the configuration, I’m willing to help where I can. I do in fact have interest in having a wired IPTV settop client connected to a satellite to simplify the overall network topology. - FURRYe38Jun 04, 2019Guru - Experienced User
Something to open a support ticket and see if you can send them the debug logs...
If Netgear provides an official response and also needs or wants to do a deeper dive into the configuration, I’m willing to help where I can. I do in fact have interest in having a wired IPTV settop client connected to a satellite to simplify the overall network topology. - gr8shoJun 05, 2019VirtuosoRight, and again, focus on the satellite, as the base works fine.
If talking to engineering, confirming support and validation testing is good enough.
Thanks so much for taking interest. - gr8shoAug 24, 2019Virtuoso
Hello, While I haven't heard back on this topic, nor have I seen mention of it in the patch notes, I decided to reconnect my ISB7005 back to the RBS50. So far it seems to be holding up well. I would of course feel better knowing something was done to improve this area of IGMP support in the satellite.
- FURRYe38Aug 24, 2019Guru - Experienced User
What was the version of FW prior to what you have loaded now?
Nothing in the release notes?
- gr8shoAug 26, 2019Virtuoso
I've stepped through most of them, but the better question is what was the last version I tested this on, and I'm thinking .44, but not 100% sure.
As to the release notes question, I hadn't spotted anything that seemed connected to the reported issue. - FURRYe38Aug 26, 2019Guru - Experienced User
Might ask Blanca_O to see if she can pull some infomation. I guess if v30 is working when it didn't work before. Anything could have snuck in.
As to the release notes question, I hadn't spotted anything that seemed connected to the reported issue. - gr8shoSep 20, 2019Virtuoso
Maybe it was just coincidence. Problems still seem to surface when power ins interrupted. I have to fiddle withi rebooting the settop box and hope that all functions are restored. The ones that are most problematic relate to being able to pause and rewind a live stream. Given that Uverse TV is going the way of the dodo bird, it's probably not worth fussing over any longer.
- FURRYe38Sep 20, 2019Guru - Experienced User
Its possible. Have you looked into getting a different modem with your ISP? Maybe a different ISP service?
- gr8shoSep 27, 2019Virtuoso
FURRYe38 wrote:Its possible. Have you looked into getting a different modem with your ISP? Maybe a different ISP service?
Made me laugh. Sure, I'll switch service to make my Orbi work better. And while I'm at it I'll drop 800 bucks on a new Orbi. 🤨
In all seriousness, it's more likely this setup will fade into past tense as U-verse TV , IPTV, is slowly fading into non-existence.
- FURRYe38Sep 30, 2019Guru - Experienced User
Overall just seems to be a bad problem between the ISP service and Orbi. Espeically with there Modem HW.
Wouldn't need to buy a new Orbi unless you wanted AX WiFi.
- gr8shoOct 04, 2019Virtuoso
Ironically, att sells the RBK50 in their brick and mortar stores now.
The ISP service is fine. Multicast seems to be a tricky thing to get right, especially in the satellite. - gr8shoOct 04, 2019Virtuoso
FURRYe38 wrote:Have you been working with NG on this Multicast issue?
There has been no ask of me.
BTW, I was informed the U-verse wireless settop box uses standard 5GHz WiFi and supposedly can connect to the Orbi via WPS. This is mildly interesting as I prefer to wired connections for streaming video.
- gr8shoOct 16, 2019Virtuoso
An update. We've had power interruptions here which destabilized the IPTV setup. Decided to factory reset the ISB 7005 and the RBS50. Afterwards, still could not get multicast to work. Toggled the disable IGMP proxy switch on and off, and magic happened. Seems the procedure I followed doesn't sync that setting correctly.
- FURRYe38Oct 16, 2019Guru - Experienced User
What proceedure was that?
Interesting. So its working now?
gr8sho wrote:An update. We've had power interruptions here which destabilized the IPTV setup. Decided to factory reset the ISB 7005 and the RBS50. Afterwards, still could not get multicast to work. Toggled the disable IGMP proxy switch on and off, and magic happened. Seems the procedure I followed doesn't sync that setting correctly.
FURRYe38 wrote:What proceedure was that?
Yeah, it's working. I can tell when there's a problem as the settop box struggles to stream a channel, pause live TV control fails, or other WiFi devices have trouble connecting.
The procedure as such used here was to factory reset the Cisco settop box, which turned out to be unnecessary, and then to factory reset the Orbi satellite. When neither of these made a difference, I decided to toggle the IGMP switch in advanced settings using the web GUI , which apparently did the trick.
Sounds like there maybe a minor bug in the operation of this toggle switch then. Something to mention to NG.Nice find.
- gr8shoDec 11, 2019Virtuoso
I tested Uverse TV running the Orbi in AP mode. There is no IGMP setting in this configuration. Was able to stream live TV with the settop box connected to a satellite hardwired. However the controls to timeshift the stream did not work, and was unable to retrieve the recordings info from the DVR.
- FURRYe38Dec 11, 2019Guru - Experienced User
When in AP mode the Orbi acts only as a data traffic pass-thru. You should be able to access any and all data sources. I would review the main host routers configuration.
