Shawnborror
Apr 16, 2020Aspirant
Orbi and AT&T Uverse unable to connect and need SIMPLE instructions
I can't follow some of hte instructions listed here - they are a bit more technical than I can grasp. I have the ORBI and called support and can get to the orbi admin page via browser. I guess I need to changes settings in my modem but am not following the instructions provided. Additional - lower level info would be very helpful.
Couple of options,
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.https://www.f0il.com/how-to-arris-bgw210-700-modem-router-with-netgear-xr500-router/
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- ShawnborrorAspirant
So if I understood anything that was in this post I would try it- I don't know what you are saying about a bridge...etc. Because of Covoid I can't get to AT&T support.
For ease of setup and installation, I would recommend trying option #3 first...
