gkappny
Jun 01, 2018Aspirant
Orbi and Battlefield One
So...I have the RBK50 system.
2 cpus plugged into the Orbi, speedtest are perfect. While I'm playing games on either CPU I get some crazy lagspikes. I'm usually hooking into games doing 20Mbps,...
Jun 02, 2018Guru - Experienced User
What is the distance between the router and satellite? 30 feet minimum to start.
Also remember that the satellite is having to capture, repeat and rebroadcast traffic which can impact performance with critical apps like gaming. So it might be best to get the satellite wired back haul going.
