Guytech's avatar
Guytech
Apprentice
May 03, 2017
Orbi and Bose Soundtouch
Since the last software update to  V1.9.1.12 I have issues controlling my Bose WiFi systems. If the device is connected to a satellite, I cannot control it with a device connected through the router and vice versa. Switching beamforming and MU-MIMO on or off did not change it. Switching satellites off so that only the router works resolves it. Very frustrated...
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello guytech
    so anytime a unit is connected to a satellite you can not control it?
    DarrenM
    • Guytech's avatar
      Guytech
      Apprentice
      Hi Darren
      Yes, you are correct. At startup the Bose app keeps restarting at 3-4 second intervals. I tried several different things. I eventually deleted the Bose apps on my computers and reinstalled it. Up to now this seems to have resolved the problem. I cannot explain why it seems that  the software update changed it's functionality.
