yammahaw
Dec 10, 2019Follower
Orbi and Cneturylink Fiber
Current configuration:
Internet - 1 GB symetrical Fiber Internet
Network equipment: Orbi RBK53
ONT > ORBI System
Issue
I have an orbi system in my house and the issues I am experiencing is I have to constantly restart the system due to download and upload speeds being less than optimal. Currently on 5gHZ band I am getting like 100 down and 40 up. The speeds are slightly better when I run the speed test through the orbi system itself but no where near the 1 GB speeds. Has anyone else experienced this?
1 Reply
What is the Mfr and model# of the ISP ONT the NG router is connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Has a factory reset and setup from scratch been performed since last FW update?
