mdroyle
May 31, 2019Aspirant
Orbi and Draytek issue
I have used the Orbi in AP mode v succesfully with BT Smarthub and also a Netgear modem. I now want to use a Draytek 2862 for the routing with Orbi still in AP mode. But when I introduce the Draytek ...
May 31, 2019Guru - Experienced User
Try a power OFF of both new modem and Orbi for 30 seconds then back on.
When in AP mode the Orbi RBR should get a IP address from the modem. Should setup the same way as the other modems.
Try a factory reset on the RBR and setup from scratch and configure AP mode. Do other devices connected to the modem get an IP address?
