moelygaer
Jan 05, 2018Aspirant
orbi and draytek vigor 130 no internet
SO my orbi rbk50 is working fine with a cheap and cheerful dlink modem. THEN I decide to upgrade the modem to a draytek vigor 130 and no internet connection. Good support from draytek established I c...
DarrenM
Jan 08, 2018Sr. NETGEAR Moderator
Have you tried to factory reset the unit by holding the reset button on the Orbi for 10+seconds then you will have to set up the orbi router again.
DarrenM
- moelygaerJan 09, 2018Aspirant
I tried this, hard reset the orbi with the new modem attached and it worked YAY
thanks for the help
