ableman42
Feb 11, 2019Guide
Orbi and Epson XP620
Everythings working great with new mesh/satellite- except my Epson XP-620 doesn't even see the router as an option to connect to. When I do the wi-fi wizard it only brings up the old router as an opt...
- Feb 12, 2019
It's resolved.
I reset the printer to original the original network settings, and a bunch of routers (including the key one) showed up.
No idea what was actually the problem, but this worked.
JoeCymru
Feb 11, 2019Virtuoso
A couple of options:
When going through the Wizard, press the cancel button when you do not see the network, scroll through until you see "Other Networks" and OK it. and proceed to manually enter and log in.
If the above does not work, delete the software for your printer on the computer where it resides, then go to epson download site and reinstall the software and start form scratch.
