ableman42
Feb 11, 2019Guide
Orbi and Epson XP620
Everythings working great with new mesh/satellite- except my Epson XP-620 doesn't even see the router as an option to connect to. When I do the wi-fi wizard it only brings up the old router as an opt...
- Feb 12, 2019
It's resolved.
I reset the printer to original the original network settings, and a bunch of routers (including the key one) showed up.
No idea what was actually the problem, but this worked.
Feb 12, 2019Guru - Experienced User
Any progress on this? Let us know
Epson Network Interface Specifications
Wi-Fi
| Standards | IEEE 802.11 b/g/n |
| Security | WEP (64/128 bit)
WPA-PSK (AES); complies with WPA2 with support for WPA/WPA2 Personal |
| Frequency range | 2.4 GHz |
| Coordination modes | Infrastructure mode
Ad hoc mode (not supported for IEEE 802.11n) Wi-Fi Direct (not supported for IEEE 802.11b) Note: Simple AP mode is compatible with Wi-Fi infrastructure mode.
ableman42 wrote:
Everythings working great with new mesh/satellite- except my Epson XP-620 doesn't even see the router as an option to connect to. When I do the wi-fi wizard it only brings up the old router as an option.
FYI phone and Roku are set up feet away and get full wifi signal.
Appreciate advice.
I did see similar posts but most were older and didn't mention the 'not even seeing the router' problem.
Thanks,
Sean
ableman42
Feb 12, 2019Guide
It's resolved.
- FURRYe38Feb 12, 2019Guru - Experienced User
Possibly something in a bad state on the printer. Glad the reset worked for you.
Please mark your post thread as solved so others will know for future reference.
Enjoy. :smileywink:
