Jazzper2
Jun 16, 2020Guide
Orbi and EX8000
I recently replaced my R6400 and EX8000 extender with an Orbi RBK40 and one satellite. However, I need an ethernet port in the room where the etender was previously located so I tried to get the EX8...
CrimpOn
Jun 16, 2020Guru - Experienced User
Did you try the WPS setup?
https://www.downloads.netgear.com/files/GDC/EX8000/EX8000_QSG_EN.pdf
- Jazzper2Jun 16, 2020Guide
Good idea....I'm a "put the info in manually" kind of guy but it's worth a shot-:)
Just tried your WPS idea -- no luck, even from about 12" away from Orbi. I then thought maybe it does not like using the same SSID so I tried it with "EXT" on the end of the names but same result. I go to the EX8000 admin screen via an ethernet connection, it lools like it sees the Orbi WiFi SSID, I put in the passkey and it looks like it takes it, but after I hit "Continue" it says it cannot connect.
When I use a different SSID for the extender, I can connect to it via Wifi but can't go any further. A traceroute dies there and when I connect to the Orbi, it does not see the EX8000 in its list of connected devices.
I'm out of ideas!
- CrimpOnJun 16, 2020Guru - Experienced User
Hmmm. The installation document never mentions any specific brand of WiFi system. My understanding is that the WPS method and "entering stuff" are mutually exclusive. At least it has been on other Netgear WiFi extenders I have installed. I would Factory reset the EX8000. Perform the WPS setup. Then get out a WiFi Analyzer program and see what WiFi networks have strong signals. I believe on one of my "dual band" extenders I had to follow the advice to do the WPS a second time. AFTER it is connected and working is the time to connect to the EX8000 management web site and mess around with SSID's.
