Jazzper2
Jun 16, 2020Guide
Orbi and EX8000
I recently replaced my R6400 and EX8000 extender with an Orbi RBK40 and one satellite. However, I need an ethernet port in the room where the etender was previously located so I tried to get the EX8...
Jun 16, 2020Guru - Experienced User
There have been incompatibilities with EX and Orbi in the past.
Has the FW on the EX8000 been updated?
Jazzper2 wrote:I recently replaced my R6400 and EX8000 extender with an Orbi RBK40 and one satellite. However, I need an ethernet port in the room where the etender was previously located so I tried to get the EX8000 to connect to the Orbi. I go thru its configuration and it sees the SSID and accepts the passkey but then it say it's not connected. I even tried setting it up right next to the Orbi and got the same results. I don't understand why the EX8000 cannot connect to the Orbi via WiFi -- are they not compatible? Running an ethernet cable out to the other room is not an option. If for some reason the EX8000 and Orbi are not compatible (why?), are there other options or should I just return the Orbi?
