WRPowers
Jan 07, 2019Tutor
Orbi and extender
I have recently installed an RBK50 Tri-band router and satellite - both on either end of the main level of my house. I have a basement location were there seems to be s signal "null" where a secur...
- Jan 07, 2019
JoeCymru wrote:
Let me spend your money. Rather than trying to go really low cost (and I have one of those Netgear extenders if you really want to go cheap ... I put it away when I got Orbi because one of my main goals was to make that mickey mouse EX6100 go away and get rid of the multiple SSID's).
If it was me, for filling the hole, I would go with a cheaper, smaller Orbi. Say an RBS20 add on, or and RBW30 add on. Again, it is your money, but for all the hassle of using an extender with Orbi for what it is actually going to put out, I would throw some additional bucks at it (but not for another RBS50 for sure). Just my opinion, naturally.
For this application, to cover a security camera in a basement, where no roaming is needed, I really don’t see an advantage for using an Orbi satellite over an extender apart from central management.
An additional satellite will have the same or more level of noise on the existing Orbi wifi network.
Jan 07, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
You can give it a try and see if it will connect and help extend the signal some. Just be aware there maybe differences in connetion rates and speeds between the Orbi and EX6100. If it doesn't seem to work well, I would get you same RBS50 satellite to place down in the base ment.
WRPowers
Jan 07, 2019Tutor
Home is about 5000 sf. Straignt line distance between the router and satellite is appx 55 ft. - two walls in between. Camera one floor below about half way between the two. Could be the best solution is just another satellite. Just though I'd try repurposing the previous extender. Thanks for your response.
