WRPowers
Jan 07, 2019Tutor
Orbi and extender
I have recently installed an RBK50 Tri-band router and satellite - both on either end of the main level of my house. I have a basement location were there seems to be s signal "null" where a secur...
- Jan 07, 2019
JoeCymru wrote:
Let me spend your money. Rather than trying to go really low cost (and I have one of those Netgear extenders if you really want to go cheap ... I put it away when I got Orbi because one of my main goals was to make that mickey mouse EX6100 go away and get rid of the multiple SSID's).
If it was me, for filling the hole, I would go with a cheaper, smaller Orbi. Say an RBS20 add on, or and RBW30 add on. Again, it is your money, but for all the hassle of using an extender with Orbi for what it is actually going to put out, I would throw some additional bucks at it (but not for another RBS50 for sure). Just my opinion, naturally.
For this application, to cover a security camera in a basement, where no roaming is needed, I really don’t see an advantage for using an Orbi satellite over an extender apart from central management.
An additional satellite will have the same or more level of noise on the existing Orbi wifi network.
gamesapk
Sep 09, 2026Aspirant
Orbi and extenders can work well together when you need stronger Wi-Fi coverage in areas where the main router signal is weak. A stable setup can make streaming browsing and gaming smoother. For casual gaming entertainment some users also explore options like Y999 Game as part of their online entertainment routine.
