Hermosaman
May 29, 2017Guide
ORBI and Frontier FIOS (Quantum G1100 Router) Internet Drops
I have the Orbi RBR50 (Router + 2 satellites) with v1.10.1.2 connected in AP mode to my Frontier FIOS Quantum G1100 Router, with the FIOS Wifi disabled. My internet, wifi AND the FIOS router ethernet, drops for approximately 6 seconds every 15 minutes, to the second. I am running Net Uptime Monitor that tracks drops greater than 5 seconds. This affects the devices connected directly to the FIOS Router via ethernet LAN. This is not really noticeable with regular internet activity, but is definitely a problem with PS4 online gaming and my Ooma VOIP phone connected directly to the FIOS router. Otherwise, the internet signal and connectivity are great.
If I disconnect Orbi from the FIOS Router, the internet failures cease to happen.
I have confirmed that BEAMFORMING and MU-MIMO are disabled.
Any ideas before returning the Orbi to Costco?
Thanks!
- DarrenMSr. NETGEAR Moderator
Hello Hermosanman
Have you tried another Ethernet cord? have you tried another port on the router to connect orbi to?
DarrenM
Hi Darren - Yes, I have tried a different ethernet cord and different ports. What I find interesting is that the entire internet connection from the FIOS router is dropped every 15 minutes, almost to the second, only when the Orbi is plugged in.
I can provide the Net Uptime Monitor log if that helps.
Thanks!
I am not familiar with FIOS routers but is there a address reservation of allow list in the router that you can add the Ip address of orbi to?
DarrenM
