Charlesknight
Jun 02, 2020Tutor
Orbi and FTTP - most update information?
Hello, I can see questions have been asked before but want to double-check none of the information has changed. I am about have BT full fibre 900 turned on - few questions: 1) I plan to plug...
Jun 03, 2020Guru - Experienced User
Charlesknight wrote:Hello,
1) I plan to plug the ONT direct into the orbi and not take the BT smarthub even out of the box - that will work fine once I've entered BT creditionals? Ask your ISP about this to see if this is supported.
2) I'm aware of the limitations of wifi but any settings tweaks to get every last mb for wifi devices?
Check to see that Beamforming and WMM are enabled. MIMO as well if you have any MIMO supporting devices.
3) I have a couple of AX devices and was thinking of maybe looking at upgrading to the Orbi AX kit - worth it?
Up to you. You'll have to test an AX system out to see if it worth it to you.
