gersonrose
May 22, 2017Tutor
Orbi and Global Cache iTach
I use a Global Cache iTach Wifi to IR, but I've not been able to get it to connect to my newly installed Orbi system. Has anyone had any success with this? Thanks in advance.
- Jun 01, 2017
Just an update on this.
I disabled 20/40 MHz coexistance on the Orbi and the iTach was able to connect again.
So, I guess that's the solution.
DarrenM
May 24, 2017Sr. NETGEAR Moderator
Hello gesonrose
I am not familiar with that product are you able to give some more detail on the issue you are having.
DarrenM
- gersonroseMay 24, 2017Tutor
This unit is designed to allow you to send signals from your wifi remote control (I use Simple Control) to control IR devices. I actually just heard back from the manufacturer's support dept. who stated the following: "Unfortunately, we have determined there is an issue with the Netgear Orbi and the iTach WiFi units. We have been investigating, but there has been no resolution yet. We believe it has to do with their implementation of 802.11b."
