gersonrose
May 22, 2017Tutor
Orbi and Global Cache iTach
I use a Global Cache iTach Wifi to IR, but I've not been able to get it to connect to my newly installed Orbi system. Has anyone had any success with this? Thanks in advance.
- Jun 01, 2017
Just an update on this.
I disabled 20/40 MHz coexistance on the Orbi and the iTach was able to connect again.
So, I guess that's the solution.
st_shaw
May 24, 2017Master
I too have Simple Control and iTach. I was unable to connect when I first bought Orbi. A few weeks later I tried again and it connected. Then another firmware update came and it no longer connects. I will probably buy a wired version of iTach to resolve the issue.
