gersonrose
May 22, 2017Tutor
Orbi and Global Cache iTach
I use a Global Cache iTach Wifi to IR, but I've not been able to get it to connect to my newly installed Orbi system. Has anyone had any success with this? Thanks in advance.
- Jun 01, 2017
Just an update on this.
I disabled 20/40 MHz coexistance on the Orbi and the iTach was able to connect again.
So, I guess that's the solution.
st_shaw
Jun 01, 2017Master
- gersonroseJun 01, 2017Tutor
That's awesome, ST_SHAW! Are you able to determine if disabling 20/40 MHz coexistance has any other impact?
Thanks!
- st_shawJun 02, 2017Master
I haven't noticed any other impact.
