PDaddy
Jul 04, 2017Guide
Orbi and Haiku Home - Big Ass Fans - Problems
I have six Haiku Home - Big Ass Fans. H series and L series. The fans communicate with the wall switches over WiFi. I can turn them on and off from my phone or tablet or from Amazon Echo or from W...
PDaddy
Jul 05, 2017Guide
Mikey:
The problem only occurs with the wall switch. The handheld remote, app, and Amazon Echo control work fine.
The Haiku home folks have duplicated the problem but have not been able to create a fix. They have been in touch with Netgear, but not gotten any headway on that front either. I am not sure how between the two of them, this is still a problem.
It is truly a baffling problem. I have not messed with the settings yet out of concern for causing other problems.
-Pat
Mikey94025
Jul 06, 2017Hero
There should be no danger changing wifi settings and others are running with such changes (myself included). You really should try disabling beamforming and mu-mimo because that works for Dropcam/Nest camera dropouts.
