ares650
Aug 16, 2017Guide
Orbi and Haiku Home - Big Fans - Problem
Useing my Orbi router and and connecting my Haiku fan to it. I am experincing a loss of connection to the router after about 15min. If I remove my Orbi router and replace it with my linksys nonmash...
- Aug 16, 2017
ares650 wrote:I currently have both "enable MU-MIMO" and "enable implicit BEAMFORMING" enabled and I am getting those disconnects.
what fw are you on? If its 1.12.0.18 see the discussion thread on this firmware and possible downgrade options till a fix comes.
ares650
Aug 16, 2017Guide
cyberprashant
Aug 16, 2017Luminary
- Mikey94025Aug 16, 2017Hero
My Haiku Big Ass fan hasn't had any issues with my Orbi. You mention things working if you switch back to your old router -- Did you repair your fan to the wireless after switching to the Orbi? Things may not work correctly if you depend just on having the same SSID between your old router and your new Orbi. Would be best to connect fresh and see if that fixes things.
- ares650Aug 17, 2017Guide
Mikey94025 wrote:My Haiku Big Ass fan hasn't had any issues with my Orbi. You mention things working if you switch back to your old router -- Did you repair your fan to the wireless after switching to the Orbi? Things may not work correctly if you depend just on having the same SSID between your old router and your new Orbi. Would be best to connect fresh and see if that fixes things.
I have to proform a hard reset on the fan about every time that I want to use the model app.
I am on FW v1.12.0.18..... I would need to read up on how to do the FW downgrade.
cyberprashant wrote:what fw are you on? If its 1.12.0.18 see the discussion thread on this firmware and possible downgrade options till a fix comes.
Would you say that FW 1.11.0.20 would be the one to try or an oldier one?
- ares650Aug 18, 2017Guide
Thank you!!!!
I downgraded FW 1.12.0.18 to 1.11.0.20 seemed to fix the issue.
The before would only stay connected for about 15min, and now its been two days with no issues.
- Retired_MemberAug 22, 2017
Hi.
Are you still experiencing this issue?
Orbi automatically updates to the latest firmware version. Do you have to downgrade to 1.11.0.20 everytime?
- ares650Aug 22, 2017Guide
@Tom0o wrote:Hi.
No...Issue is fixed.
I know when I log into the app it asked to upgrade to the lastest Firmware. But after the downgrade to 1.11.0.20 it has not upgrade on its own.
