ares650
Aug 16, 2017Guide
Orbi and Haiku Home - Big Fans - Problem
Useing my Orbi router and and connecting my Haiku fan to it. I am experincing a loss of connection to the router after about 15min. If I remove my Orbi router and replace it with my linksys nonmash...
- Aug 17, 2017
ares650 wrote:I currently have both "enable MU-MIMO" and "enable implicit BEAMFORMING" enabled and I am getting those disconnects.
what fw are you on? If its 1.12.0.18 see the discussion thread on this firmware and possible downgrade options till a fix comes.
cyberprashant
Aug 17, 2017Luminary
Mikey94025
Aug 17, 2017Hero
My Haiku Big Ass fan hasn't had any issues with my Orbi. You mention things working if you switch back to your old router -- Did you repair your fan to the wireless after switching to the Orbi? Things may not work correctly if you depend just on having the same SSID between your old router and your new Orbi. Would be best to connect fresh and see if that fixes things.
- ares650Aug 17, 2017Guide
Mikey94025 wrote:My Haiku Big Ass fan hasn't had any issues with my Orbi. You mention things working if you switch back to your old router -- Did you repair your fan to the wireless after switching to the Orbi? Things may not work correctly if you depend just on having the same SSID between your old router and your new Orbi. Would be best to connect fresh and see if that fixes things.
I have to proform a hard reset on the fan about every time that I want to use the model app.
