Shofam's avatar
Shofam
Follower
Jul 22, 2019
Orbi and hardwired connections
Since I only have one ethernet port on my Orbi router (my older router had 4) how do I connect my Hue hub, my Arlo hub and my samsung Smarthings hub? Would a splitter work?  Any thoughts?
TIA
1 Reply
  • FURRYe38's avatar
    You can always attach an external Non managed, non green ethernet Gb LAN switch to the back of the RBR and then connect other LAN devices to this switch. They make them starting with 5 ports, 8, 16, 24, 48 ports models. There inexpensive as well.
    Example:
    https://www.netgear.com/support/product/GS108.aspx
