Heather725
Feb 04, 2018Follower
Orbi and Hue Lights
I have an orbi RBR50 and just recently purchased the Hue starter pack. I have the hue wired into the orbi which is the same as my computer and all is connected to ATT wireless router. I can get the h...
st_shaw
Feb 04, 2018Master
I have Hue lights with Orbi and everything works fine. I'm not sure what is causing your issue, but if you are connecting Orbi to another router, then make sure you set Orbi to Access Point mode.
