Bigguy1
Apr 18, 2019Aspirant
Orbi and iOS compatible?
Having trouble with all ios and tvOS devices since I installed orbi: phones, iPads, Apple TVs. Cannot download apps, HBO GO and Netflix media wont play, Apple Music won’t play. Running on v2.3.1.4...
- Apr 18, 2019
Try setting a custom DNS address of 1.1.1.1 and 9.9.9.9
Orbi is iOS compatible.
Has the ISP modem and Orbi been powered off for 1 minute then power ON the modem and let it sync then power ON the Orbi base and then try?
The Orbi is directly connected to the modem correct?
SW_
Apr 18, 2019Prodigy
Ignore this if you don't use Disney Circle. If Disney Circle is enabled, try to disable it and then reboot the router. Disney Circle takes a few minutes to take effect.
Bigguy1
Thank you. I have not turned the Disney s/w on yet. Was looking forward to trying it if I can get this darned thing to work.
