Bigguy1's avatar
Bigguy1
Orbi and iOS compatible?
Having trouble with all ios and tvOS devices since I installed orbi: phones, iPads, Apple TVs. Cannot download apps, HBO GO and Netflix media wont play, Apple Music won’t play. Running on v2.3.1.4...
  • FURRYe38's avatar
    Apr 18, 2019
    Try setting a custom DNS address of 1.1.1.1 and 9.9.9.9
    Orbi is iOS compatible.
    Has the ISP modem and Orbi been powered off for 1 minute then power ON the modem and let it sync then power ON the Orbi base and then try?
    The Orbi is directly connected to the modem correct?
