metime's avatar
metime
Star
Sep 24, 2020
Orbi and Knighthawk D7800 working together
Hi All,
I have a Nighthawk X4S D7800 but needed better coverage of WiFi so bought 3 Orbi mesh network routers. Can anyone please advise what configuration I need to put each of the devices in. Orbi RBR50 is in router mode, and down as not needing a password and login from my ISP. my Dl800 is also in router mode but wifi switched off and uses the login for ISP, and I HAVENT enabled Access Point mode as when I do nothing works. it is currently working with Orbi as the wifi but Im not sure this is correct as i do keep having issues with my wifi?
Any help would be great?
1 Reply
  • metime wrote:
    Hi All,
    If you are going to keep the Nighthawk in router mode with WIFI off, set the Orbi router to AP mode. You will nbeed to reboot the Nighthawk router when changing the Orbi to AP mode. Otherwise the Orbi will never connect.
