mljones6
Apr 03, 2018Aspirant
Orbi and Lennox iComfort thermostat
I've just had a new Lennox iComfort thermostat installed, and it will not connect to Orbi. The thermostat will connect to my iPhone hotspot, but not Orbi. The thermostat shows a good WiFi signal fro...
sc13
Oct 27, 2018Tutor
I just solved this problem by going back one version of firmware in my Orbi.
for me, this is where I was able to get a previous version
https://www.netgear.com/support/product/RBR20.aspx#download
then I logged into my system
Advanced > Administration > Firmware Update
Then click Browse, and search for the firmware file that you downloaded
Make sure that you select the device then click Update
Oct 27, 2018Guru - Experienced User
Thanks for letting us know...
- sc13Oct 28, 2018Tutor
Back to the drawing board. Going back one version worked until the auto update [which can't be changed] changed it back to the latest version. I was on the phone with Netgear for awhile, but still haven't resolved the issue. Same situation here, no problem connection the thermostat to my iphone.
- mljones6Oct 28, 2018Aspirant
I solved my problem a long time ago since my original post. I can't remember exactly what I did, but I do know that I googled the issue and a remedy was posted. As I recall, I had to go into Orbi's advanced settings to deselect some settings. Sorry I'm not much help.
Solved the problem. Took Orbi out of the loop. I had another wifi network available and it has been working very well. Don't know why Lennox and Orbi can't get along, but I am tired of trying to figure it out.
