Cgeorgia
Jul 18, 2020Aspirant
Orbi and Linksys
Is it possible to connect a Linksys range extender (tri-band Model RE9000 Max-Stream) as a satellite to Orbi 6?
CrimpOn
Jul 18, 2020Guru - Experienced User
Cgeorgia wrote:Is it possible to connect a Linksys range extender (tri-band Model RE9000 Max-Stream) as a satellite to Orbi 6?
The product literature says, "works with ANY WiFi router".
https://www.linksys.com/us/p/P-RE9000/
There is a community forum for the WiFi 6 Orbi "AX" products. People who participate in that forum own the "6" product and are more likely to have personal experience to relate. You might try posting in that forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
- CgeorgiaJul 18, 2020Aspirant
Thank you
