airwolf666
Nov 07, 2018Aspirant
ORBI and NEST Hello
I was using a beta version software on my orbi and the beta test was complete so i upgraded the firmware to 2.2.1.210 and ever since my NEST hello goes offline a few minutes thru out the day and nigh...
- Dec 12, 2018
I ended up using a WiFi extender that I had laying around. It is a Netgear EX6100 and using it in extender mode and using the fast line to the router on 5 ghz band, that leaves me using the 2.4 ghz band to the Nest Hello which for some reason it likes only using that. When using the fast lane you have to choose which band you want to talk with the router and then the other band are for your devices. Since I have done this I have not had any discounts from the internet.
airwolf666
I actually had on beam forming in the beginning and then turned it off and tried it and then turned off MU-MIMO. I am thinking of turning off or unchecking the fast roaming but don't think this is a problem because the router is 6 feet away from the nest and satellite is far away in the back of the house. When checking the satellite i have never seen the nest hello connected there.
Nov 07, 2018Guru - Experienced User
Try this, set WPA to disabled temporarily. See if the NEST will connect. If so, try WPA and Auto. Not WPA2.
- airwolf666Nov 07, 2018Aspirant
The NEST Hello is connect to the ORBI most of the time but every so often it disconnects for a few minutes and then connects again.
- FURRYe38Nov 08, 2018Guru - Experienced User
See if setting manual channel 1, 6 or 11 helps.
Try WPA2 and AES only.
- airwolf666Dec 12, 2018Aspirant
