airwolf666
Nov 07, 2018Aspirant
ORBI and NEST Hello
I was using a beta version software on my orbi and the beta test was complete so i upgraded the firmware to 2.2.1.210 and ever since my NEST hello goes offline a few minutes thru out the day and nigh...
- Dec 12, 2018
I ended up using a WiFi extender that I had laying around. It is a Netgear EX6100 and using it in extender mode and using the fast line to the router on 5 ghz band, that leaves me using the 2.4 ghz band to the Nest Hello which for some reason it likes only using that. When using the fast lane you have to choose which band you want to talk with the router and then the other band are for your devices. Since I have done this I have not had any discounts from the internet.
airwolf666
The NEST Hello is connect to the ORBI most of the time but every so often it disconnects for a few minutes and then connects again.
Nov 08, 2018Guru - Experienced User
See if setting manual channel 1, 6 or 11 helps.
Try WPA2 and AES only.
- airwolf666Dec 12, 2018Aspirant
- FURRYe38Dec 12, 2018Guru - Experienced User
Great. Glad you got it working well.
Enjoy.
