CP5262
Aug 03, 2020Aspirant
ORBI and Nest Thermo
Nest therostat cannot see ORBI RBR 40 network. I've read putting it in AP mode solves the problem. but when I put ORBI in AP mode I lose all wifi. My fix was to reset orbi to factory settings and ...
Aug 03, 2020Guru - Experienced User
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
