CP5262
Aug 03, 2020Aspirant
ORBI and Nest Thermo
Nest therostat cannot see ORBI RBR 40 network. I've read putting it in AP mode solves the problem. but when I put ORBI in AP mode I lose all wifi. My fix was to reset orbi to factory settings and ...
nicholb
Aug 03, 2020Luminary
CP5262 wrote:Im using an Arris surfboard modem - I was told to turn off wifi on it so only wifi on orbi is "on" so as not to interfere. How do I connect NEST and keep internet on?! Thanks very much.
If you just turned off WiFi on the modem/Router you are most likely in a double NAT situation with both the Orbi and Arris acting as routers. This will cause probalems for many things. You have two options to fix that.
1. Go into your Arris and set it to "bridge mode". You'll probably be able to find this by Googling the model number and bridge mode. This I would say is preferable as it leaves all the Orbi router features active.
2. Switch the Orbi to Access Point mode. This shuts off the Orbi's router functions. I know you said you tried this already and it is hard to guess what whent wrong. It could have been you did not have DHCP on at the Arris, or it could be the IP address assigned to the Orbi was not in the correct subnet. It could also be something else. Try to get option 1 working first.
- MstrbigAug 03, 2020Master
What Arris surfboard modem do you have? I also have an Arris AB8200, but it is just the ISP modem, so there is no configuration.
Have you tried resetting your Nest? Just remember resetting will lose all data on the Nest and you will have to set it back up.
