morrisseysb's avatar
morrisseysb
Apprentice
Sep 16, 2017
Orbi and NEST
Anyone else have NEST devices and notice that they do not connect to the satellite?  I have a house full of NEST devices and there are several that are way closer to the satellite but are connecting to the router instead.  Other devices seem to connect to the closest unit, like my web cam and tablets.
  • I only have the Nest thermastat but it is connected to the satellite with no issues.
    • morrisseysb's avatar
      morrisseysb
      Apprentice
      I have the Thermostat also, the latest version and several Nest protects.  Not one is connecting to the satelite and most of them are way closer to it.
        morrisseysb
        Apprentice
        Ok i take that back the thermostat is connecting to the sat....but the protects are not.
  • It may depend on your location.  In Canada, Nestcams only support 2.4ghz, ie no 5ghz for Nestcams in Canada....
  • I just setup the orbi and notice this too. The satellite is less than 5 feet from it, but it would rather connect to the router 40 feet away. All my nest cam are doing that
  • Apparent Nest confirm issue with Orbi
    • MrX911's avatar
      MrX911
      Apprentice
      If you are running 2.1 firmware on Orbi,there are issues with clients incorrrectly showing up as all connected to the router when actually they are not.
